FANUC I/O
Question
Hello! I am having trouble using the setDO command on robodk, and was unable to understand fully what the solutions were on other similar threads. Simply running that i/o command with a number as the name, and 1 as the value, had no visible effect on the robot's teach pendant. Any help with what code to write in, or any other suggestions would be greatly appreciated!
Thank you,
Jeremiah~Millersville Robotics
Are you controlling the robot using a Driver or using a Post Processor to generate a program to later load into your controller?
(04-15-2022, 03:36 AM)Alex Wrote: Are you controlling the robot using a Driver or using a Post Processor to generate a program to later load into your controller?
I am controlling the robot through the use of a driver.
