Failed to generate program "weld" Python Post Process exit code: 0
Trying to use trial version of RoboDK. When attempting to generate a program we get the an error with exit code 0. The full message is as follows:
"Failed to generate program "weld" using post processor "fanuc_r30i"
post processor path: C:/roboDK/posts/fanuc_R301.py
c:\robodk\python37\python.exe: can't open file 'c:/users/username/appdata/local/temp/postweld.py' : [errno 13] permission denied
Python Post Processor process exit code: 0
Are you able to open the file that the error claims is unable to open?
You can try to open it with Notepad or any text editor.
Does it work if you run RoboDK using Administrator privileges?
sorry i didnt see the reply i have been away. there is no postweld.py file in that location it is not being generated.
Do you have the right access to create files in your temp folder?
Can you try starting RoboDK using administrator privileges?
