11-20-2026, 06:02 AM
The behavior of RoboDK simulation and the actual CRX-30iA robot differs from each other.
Could you advise me on model settings or whether a model update is available?
Background
We are controlling a Fanuc CRX-30iA with RoboDK.
About a year ago, when we downloaded the CRX-30iA model, we found that the robot's actual behavior differed from the simulation, so we have been using the CRX-25iA model, which did not have this discrepancy.
Recently, we downloaded the models again and found that both the 30iA and 25iA now exhibit this discrepancy, so we would like to resolve this issue.
Actual Robot Behavior
When we command J2 to move on the actual robot arm, J3 also moves in coordination to keep the link between J3 and J4 at the same angle. However, the J3 encoder value does not change.
The J3 posture appears to be influenced by both J2 and J3 axes. For other axes, this type of coordination does not occur.
RoboDK Model Behavior
The CRX-25iA model we downloaded previously reproduced the same coordination as the actual robot.
However, the CRX-25iA and CRX-30iA models we downloaded recently show only J2 moving during single J2 operation, and the maintenance of the same angle of the link between J3 and J4 is not reproduced.
This difference can be confirmed in the simulation without connecting to the actual robot. When connected to the actual robot, the same discrepancy appears in the actual behavior.
Screenshots
For reference, I will attach screenshots of the RoboDK interface with the same axis values applied to both old and new models.
The left screenshot shows the previously downloaded model, which matches the actual robot's posture, while the right screenshot shows the latest model where J3's posture differs from the actual robot even when the same axis values are applied.
Environment
- Robot Arm: Fanuc CRX-30iA
- RoboDK Version: 6.2.1 (x64)
- PC: Windows 11 Pro 24H2
Questions
1. Can I adjust the settings to achieve the same coordination as the actual robot?
2. If not possible through settings, would it be possible to provide or update the CRX-30iA model that reproduces the actual robot's behavior?
I will attach a project using a previous CRX-25iA model that reproduces the special behavior.
If you need any additional information, please let me know. Thank you for your help.
Background
Screenshots
Environment
Questions
