11-21-2025, 05:24 PM
I am trying to setup a WAAM or ArcDED process with a Fanuc Arc Mate 100id using a R30ib plus controller.
I am using both Slic3r and the 3D print project for toolpath generation which is working well.
My issue now is trying to add in the "Weld Start" and "Weld End" commands when needed into the robot program.
I have tried using Program Events without any success.
Through searching the forum I and RoboDK site I found that the ProgamCall section of the robot's post can be directly edited to intercept M codes and insert custom code.
I tried reaching out to support and they directed me to post here on the forum to get help.
I am trying to also request source code for the R30ib Plus post as it is currently in the compiled .pyc format.
Any help or ideas anybody has about how to implement automatic insertion of "Weld Start" and "Weld End" commands would be great. I ideally would like to be able to use other slicers besides Slic3r or upload an NC file directly to the 3D print project and still be able to insert the proper "Weld Start" and "Weld End" code.
