Threads: 3
Thank you.
All Clear.
Regards
Threads: 3
Hi Albert
I watched a video where RoboDk controls a fanuc robot.
I am thinking if it is possible to use RoboDK as the main interface for working on the robot without touching the teach pendent ... starting the program from the PC, drip feeding editing etc...
I also have problems with the memory in the controller R 30ib plus
I cannot load a large program generated by CAM.
Can you help
Threads: 3
So I am using postprocesor in robodk J3 dripfeed or? My controler is r30ib plus?
I do not understand how does drip feed work.
should I (CTRL F6) send program to robot or?
Please what are the steps?
Threads: 3
Albert just one confirmatio,i need to start python file and it will use ethernet to send tp programs?
Whether the process will proceed smoothly?
Thanks again
226
That's correct, you should run the Python file to start sending the TP programs. You'll see some instructions through the console.
Make sure you have the correct IP address of your robot in Connect-Connect robot.
Threads: 3
Thank you Albert
Just one more question I need help with,
Does drip feed send one TP file, wait for it to execute and then send another one, or is the next TP already in the CMOS of controller waiting for execution?
so there is no interruption-delay in execution between split tp programs ?
Regards
226
The drip feeding for Fanuc sends one TP file at a time and adds/removes TP files as the robot executes them. There is a buffer of 2 or 3 TP files for this purpose.
We tested it with older Fanuc controllers that have less than a 2 MB hard drive and it works.
