FanucSM Connection Failing
Information
As of updating to version 5.4.1, I am no longer able to connect to my Fanuc robot. When I attempt to connect, I get the error, "FanucSM.exe - Entry Point Not Found". I think this means that it is failing to find the path to the driver. I've tried rebooting the PC, and re-installing RoboDK, but I still get the same error.
How can I fix this?
What happens if you press the select button linked to "Driver:".
Can you select "FanucSM" there?
Does this properly reset the path.
(04-04-2022, 05:56 PM)Jeremy Wrote: What happens if you press the select button linked to "Driver:".
I already attempted that, and it still gives the same error. FanucSM was one of the listed options, and I clicked it to set it up.
Deleting this file should solve the problem:
C:/RoboDK/api/robot/Qt5Network.dll
This is an old version of the DLL.
All drivers should take the correct DLLs from the RoboDK bin directory (with very few exceptions).
