G-Code Import Error
To whom it may concern,
I have encountered this G-code import error (picture attached) multiple times when dealing with circular movements. RoboDK does not seem to handle negative radius values. Is this a known issue?
Attached Files Image(s)
Hi gvhf,
Have you tried activating this option:
Hi Jeremy,
Yes I have tried activating that option.  The G-code import then displays no errors; however, the path is warped so the issue was not fixed. I have attached the tool path (.apt) and a picture of the imported path, which is supposed to be a simple cylinder.
.apt   cavitycyl.apt (Size: 12.63 KB / Downloads: 845)
Hi gvhf,
I informed our dev team of the issue and the other issue you bring here: https://robodk.com/forum/Thread-RoboDK-G...-Processor
Thank you Jeremy! I appreciate the timely replies. Please keep me/this thread updated whenever the issues are resolved.
Hi Jeremy,
I have generated a sample 5-axis path (.apt tool path and figure attached). The .apt file carries the correct tool orientation; however, that orientation is not recognized when imported into RoboDK (figure attached) through a robot machining project. Two of the pyramid faces have the correct orientation, but two do not.
Thank you
.apt   testingpathpoints.apt (Size: 5.68 KB / Downloads: 914)
