I would like to ask how to generate poses on a specific surface. How can I generate random poses in such a way that the robot's TCP is oriented normal to the object? I would like to generate 50 random poses. I've been looking on the forum, and they mention that object. GetPoints() can be used, but I'm not sure how to use it.
Generate Poses in object surface |
11-23-2024, 09:51 AM
You can find some examples on how to extract a point and a normal to the surface in the description of the GetPoints function (RoboDK API for Python):
https://robodk.com/doc/en/PythonAPI/robo....GetPoints
11-25-2024, 05:33 PM
(11-23-2024, 09:51 AM)Albert Wrote: You can find some examples on how to extract a point and a normal to the surface in the description of the GetPoints function (RoboDK API for Python): Okay. GetPoints() returns the xyz coordinates relative to the object, and i, j, k relative to what? If I want to orient my tool pointing to that surface, should it be oriented in the direction of -i, -j, -k? Or do I need to transform the orientations returned by GetPoints to the robot's reference frame? Thanks!!
11-26-2024, 12:43 PM
The IJK vector is the normal of the surface. This is usually the vector of the Z axis of the tool, not the Euler rotation angles.
You could use a function like the point_Zaxis_2_pose to create a pose from a point and a Z axis: https://robodk.com/doc/en/PythonAPI/robo...xis_2_pose |
| 1 Guest(s) |
Powered by MyBB
