Generating NC code from program to re-import into machining project
I have generated a program from NC code within a machining project, and then have subsequently updated some of the targets within the path manually. Is it possible to now export this new path as NC code to re-import back into the machining project. I have tried selecting various post-processors including the three with titles starting with G-Code and didn't have any luck. Apologies if it is a simple task, I am still yet to learn G-Code so am not familiar with the language and structure.
Many thanks
Paul
Hi Paul,
I'm sorry we took so long to get back to you. We have 3 post processors that allow you to generate G-code. More information about post processors here:
https://robodk.com/post-processors
The same question was posted recently here:
https://robodk.com/forum/Thread-ISO-G-Co...ut-program
