Generating programm with (call) function
While trying to generate robot program (Fanuc post processor Fanuc 30IA) and in program used call program function, I got an issue:
Failed to generate program "MP0_50" using the Post Processor "Fanuc_R30iA"
Post processor path:C:/RoboDK/Posts/Fanuc_R30iA.py
File "C:/Users/Руслан/AppData/Local/Temp/PostMP0_50.py", line 1120, in
make_program()
File "C:/Users/Руслан/AppData/Local/Temp/PostMP0_50.py", line 32, in make_program
r.RunCode(r"""GOSAFE1""", True)
File "C:\RoboDK\Posts\Fanuc_R30iA.py", line 978, in RunCode
ValueError: substring not found
Process output:
Using Python version: sys.version_info(major=3, minor=7, micro=3, releaselevel='final', serial=0)
RoboDK Post Processor: C:/RoboDK/Posts
Total instructions: 953
Python Post Processor process exit code: 1
Hi Tsvetkov,
Can you join your .rdk station?
It will help me help you.
Here it is in attachment. Try to generate a main program.
Hi Tsvetkov,
There is no file attached to your post.
Once more.
.rdk   problem.rdk (Size: 2.38 MB / Downloads: 2,327)
Hi Tsvetkov,
Can you update RoboDK to the latest version?
I just updated mine and it solved the issue.
Ok, thank you.
