I have a project using TM Robot. When I try to connect the TM robot through RoboDK, it can connect and the status is "ready" however when I try click the Get position command, the position of the robot in RoboDK can't follow the current position of the real TM robot. When I check the log, it keep sending command without another response. Do you know how to solve this problem? Thank you.
