Get/set milling project parameters through API
I'm using curves to set up a milling project and I'd like to set parameters, such as approach and retract distance or the tool following algorithm, using the API. It would be handy to be able to query them too. Is this possible? I can't see any examples or documentation to achieve this.
It is not possible to control this through the RoboDK API at this moment, however, you can change the default event settings, remove the default approach/retract and the algorithm here:
  • Tools-Options-CAM
We'll add this features through the API in the near future.
