HANWHA ROBOT CONNECT
I am trying to use the HCR-12 model among Hanwha robots.
There are models provided by RoboDK, so you can use them as simulations.
But when I try to connect to the robot, it says there is no driver.
When I checked the folder, there were other robot drivers in the C:\RoboDK\api\Robot path, but there was no Hanwha robot driver. What should I do?
Use my post (https://robodk.com/forum/Thread-RoboDK-Hanwha-Driver) as a starting point, but keep in mind that the driver is incomplete and only supports Joint Move.
Thank you!!
