[HELP] Tool changer with Mechanism
Hi guys!
What I'm basically looking for is a solution on making a tool changer in RoboDK.
I've already saw this post: https://robodk.com/forum/Thread-Automati...-in-RoboDK
And I'm pretty much doing the same thing as Jeremy suggested in his post (hiding one object, then showing the other object and etc.), but in my case, I have a mechanism on the robot's flange (fork tool) and I can't simply Show/Hide a Mechanism. Meaning that RoboDK allows me to Show/Hide only Objects and Tools, but not Mechanisms.
The thing is, the fork tool is consisted of two parts: One stationary part (that connects to the robot) and one moving part (the fork itself). And in order to move the fork forward/backward, I have to make it like a Mechanism (1 linear axis), right? That's the case. If I make it like an mechanism,
If there's a way to make a tool in RoboDK, that has an attached Mechanism on it, that would be great. But i don't think there is one (Please, correct me if I'm wrong)
I've attached my project.
Adler
.rdk   RV-35F (sus novi pozicii).rdk (Size: 12.11 MB / Downloads: 994)
Hi AdlerAdemov,
I made two python scripts, one that hide the mechanism and another one that show it, you can call these scripts with the Program Call Instruction.
Olivier
.rdk   RV-35F (sus novi pozicii).rdk (Size: 12.14 MB / Downloads: 1,068)
(03-12-2021, 03:20 PM)Olivier Wrote: Hi AdlerAdemov,
Olivier
Thank you, Olivier. I've gave it a try and it worked like a charm .
Although it worked, when I hide it, then show it, the reference frame and the target positions for opening/closing the fork tool are visible.
Can we hide them somehow after hide/show sequence?
Picture of the reference frame with the mechanism and the target positions (closed/open):
[Image: robo-DK-Tool-changer-with-Mechanism-issu...w-hide.png]
Since I've progressed a bit more in the project, I've attached it again. You can find your Python code in folder Tool Changer --> Python to Show/Hide Fork Tool.
Thank you, once more :)
.rdk   RV-35F (after Oliviers python snippet).rdk (Size: 14.57 MB / Downloads: 980)
Hi AdlerAdemov,
The way the python script work at the moment is it hide/show everything inside the reference frame.
Option A : You can put the targets inside a separate reference frame.
Option B : You can modify the python script to hide/show only the mechanism :
from robolink import *    # RoboDK API
from robodk import *      # Robot toolbox
from math import *
RDK = Robolink()
MechanismToHide = RDK.Item("My Mechanism", itemtype=ITEM_TYPE_ROBOT)
MechanismToHide.setVisible(1)
  #With 1 to set it visible or 0 to set it invisible.
Olivier
Hi Adler,
Or you can just hide them manually from the get-go.
Right-click on it in the station tree and "Visible".
You don't really need to see those at any point anyway.
(03-15-2021, 06:44 PM)Olivier Wrote: Hi AdlerAdemov,
from math import *
RDK = Robolink()
Olivier
(03-15-2021, 07:55 PM)Jeremy Wrote: Hi Adler,
Hey guys. Yeah, I've went through some of the Python API documentation earlier and I've realized that I can simply show/hide only the Mechanism itself. So I've tried both options (manually unchecking the "Visible" checkbox and automatically hide the reference frame from the Python itself). Python now does exactly what i want it to do.
Pretty easy. Worked.
I should've read some of the documentation earlier, buuuut... you know what's up when project deadline is literally in the next morning.
Thanks once more.
I have completed the project we wanted to do and I'm uploading it here. Sharing is caring :)
.rdk   RV-35F (vacuum and fork demo).rdk (Size: 14.59 MB / Downloads: 937)
Nice demo. Very cool.
Small thing to improve your experience.
"Tools"->"Options"->"Display"->"Simplify Objects"->Select the robot.
That will simplify the 3D model of the robot a bit and increase the frame rate quite a bit (it tripled it on my end, from 20 FPS, to 60 FPS).
You can see the frame rate by going to "Tools"->"Options"->"Display"->"Display text on screen"->"Render time".
That actually helped, when I've presented the demo on a slower PC. Thanks Jeremy!
It comes to my attention, that I can't see the FPS counter anywhere. I've checked the instruction and I know where should i expect it to pop out, but it doesn't appear at all.
If you are using the "opaque tree", it won't appear I think.
3 Guest(s)
