Hello, I am trying to model the Pilz PRBT_6 robot. I followed the video tutorial to create a custom mechanism. However, my robot moves weirdly when I change the values of each joint.
For example, I tried to move joint 1 and joint 2. The joints do not rotate around the axis.
I spent several hours changing build joints and theta angle without succeeding.
Can you help me to model the robot?
The complete manual of the robot is in the link: Pilz manual
The drawings of the robot and the Denavit-Hartenberg parameters are the next:
The original .step of the robot is the next
PRBT_6_2027052_D.stp (Size: 3.51 MB / Downloads: 594)
I thought that the movements did not match because when I opened the step file in the AutoDesk Inventor, the center of each joint did not coincide with the center of rotation. If that is the problem I have corrected it and attached the updated .step model. in the link
Thanks in advanced for your help!
