I am trying to build a 3 linear axes mechanism which has a pair of parallel axes.
firstly I built it with "Build/modify mechanism or robots" > "3 linear axes(H bot), while the 3 linear axes of H bot are vertical to each other and fixed.
So, Is there a way to build a special 3 linear axes mechanism( as shown in the picture, axis 1 and axis 2 are parallel and axis 3 is vertical to these axes?
