Hi all,
I am using an irb1600 robot arm. it is the 6 axis robot arm. in roboDK I can see 2 types of information on robot position. The first one is xyzabc (first 3 in distance mm, last 3 are degree). Other information is Q1, Q2, Q3, Q4, Q5, Q6. i can play with x,y,z,a,b,c by python. the problem is how can I change the Q6 only in each movement?
is there any example? can you provide a code that can change the angle of the tip? I have uploaded the file, where I want to learn ho to rotate each brick only horizontally. which is only q6.
thank you in advance
-- Dibash Adhikari
-- Architect, urban planner
-- Researcher in POSTECH
