How can I prevent J6 from rotating during Curve Follow Project?
I am using RoboDK with a Doosan A0509 robot and I am creating a path using Curve Follow Project.
I have a problem with the robot's J6 axis. I want J6 to remain at approximately 180° throughout the entire path, but during the Curve Follow motion, J6 rotates significantly.
.rdk   test3.rdk (Size: 698.6 KB / Downloads: 106)
What do you mean by prevent it from moving significantly?
In the program you shared Joint 6 moves within the range of -50 to +40 degrees approximately. This movement is required to maintain a constant tool pose.
Hello Albert,
When I create my path, I set J6 to 180°. However, when I generate the path using Curve Follow Project, J6 automatically moves to 90°.
I want J6 to remain at 180° throughout the entire path. How can I configure or program the path so that J6 stays fixed at 180°?
