How to Save and Load a customized JSON string to RDK file?
Is it possible to save a customized JSON string to RDK file?
Could this be done with setParam() and getParam()?
And, is there a related/similar example?
Yes, you can save and load strings using setParam and getParam. You should see the string as a parameter if you right click the root of your station and select "Station parameters".
More information here:
https://robodk.com/doc/en/PythonAPI/robo...k.setParam
