07-19-2024, 07:10 AM
Hi everyone,
As far as I know, KUKA provides a spline function, which is a motion type particularly suitable for complex and curved paths. I am wondering if there is a way to use the spline PTP(SPTP) function in RoboDK.
Following the documentation provided by RoboDK, I am using the kukabridge RoboDK driver in RoboDK, and I have installed the C3bridge on the KUKA robot controller with KSS 83. version, along with the RoboDKsync562.src program. This setup allows me to communicate between the KUKA robot controller and a Python-based RoboDK api server.
Currently, in the RoboDKsync562.src file that I have, only the motion commands for PTP, LIN, and CIRC are implemented. Is it possible to use SPTP with RoboDK?
Additionally, I am curious about executing a PTP_REL motion command by sending a specific trigger signal from the RoboDK API to the KUKA robot communicating with RoboDK. As far as I Know, the RoboDKsync562.src program distinguishes commands from RoboDK with COM_ACTION. Can I modify this part to handle new commands sent from the RoboDK API?
I understand that the data is packetized in the kukabridge driver, and it seems that modifying this part might be necessary. However, I do not have access to the source code for kukabridge and cannot modify it.
Could you provide guidance on how to achieve this?
Thank you for your help
