How to add targets in curve follow project only adding start and end |
09-28-2023, 04:47 PM
Do you mean you would like to export this line as 2 points? How did you create this line in the first place?
It is better to use the default curve extraction tool to have one straight line instead. If you can share the RDK project file and the 3D model we can better take a look.
10-03-2023, 05:37 AM
RoboDK-SampleProject.zip (Size: 407.77 KB / Downloads: 522)
(09-28-2023, 04:47 PM)Albert Wrote: Do you mean you would like to export this line as 2 points? How did you create this line in the first place? |
| 1 Guest(s) |
Powered by MyBB
