How to change robot configuration in Point Follow Project
I have a UR20 doing a point follow project but it keeps defaulting to the configuration as shown in the first screenshot. Wrist 3 is above wrist 1 & 2. I need wrist 3 to be below wrist 1.
No matter what I do (changed the tool TCP, change the path to tool offset) it reverts back to this configuration which will result in a tool/arm collision as it follows the path.
If I pause the simulation, I can change the configuration as required in the robot options, but the point follow reverts it back to the other configuration. I thought the "teach" button in the PFP might teach it to remember this configuration but it doesn't.
How can I change the configuration?
Could you please share your station?
(08-19-2024, 03:28 PM)Sergei Wrote: Could you please share your station?
I've gotten around it by doing the following:
Pause the simulation. Go to robot settings and select the configuration that suits best (EG configuration #3)
I then send the robot home. Go to robot settings again and change it to the same config (#3) which changes the home position but TCP is still in same place. I then set this position as the new home position and adjust if required.
When I replay the simulation, it starts from this robot configuration and keeps it throughout.
Is there a better process for this?
.rdk   UR10e Screwdriving PB1.5m table.rdk (Size: 2.3 MB / Downloads: 496)
Alternatively, you can just set joint values for the start point and, optionally, teach the tool orientation:
