How to create a palletizing robot with 4 axis
I need to use Hyundai robot 4 axis, but I can’t find it in the library and also in “Build/modify mechanism robot” it is not possible to create.
Someone can help me
To add a new robot to RoboDK we need the 3D files of your robot (preferably STEP or IGES format). It would also help if you can provide a PDF sketch with dimensions and robot related information (payload, reach, etc).
With the purchase of a Professional license we can add robots for you faster. If you have a professional license it is better if you contact us through Help-Request support.
Dear all,
also we find some difficult to implement a palletize robot (we try with CP180 from Kawasaki)
Specificaly we find two difficults:
- insert the correct cynematics (joint distance and so on)
- execpt J1, the other joints don't rotate correctly
Have you some suggestions for us?
Thanks in advance
(09-25-2023, 03:07 PM)Albert Wrote: To add a new robot to RoboDK we need the 3D files of your robot (preferably STEP or IGES format). It would also help if you can provide a PDF sketch with dimensions and robot related information (payload, reach, etc).
Did you find the solution?
i am sending my archives if anyone can help me. Sending the station with the separate parts, and the sketch (link below)
https://www.turinrobot.com/products_details/61.html
.rdk   Station - Pallet.rdk (Size: 5.07 MB / Downloads: 488)
Unfortunately no.
I tried to add a six axis and just enable only 4, but seems that something was wrong, but I don't understand what.
In my case the rotation off all axis (expect axis 1) were wrong (direction and offset)
I hope in some help from RoboDk support
