01-28-2025, 11:01 PM
Hello
I can't seem to figure out how to get RoboDK to use Cartesian coordinates to define positions. I've messed with every setting I could find.
I'm working on a palletizing program and I need all the moves to be in relation to the frame I have defined. I have the program start by going to a target above my pallet "AboveA", then progress through some moves and a drop program, then I have it return to AboveA.
The problem is that the first move to AboveA is a joint move that is defined by a joint position. The second time it goes to AboveA is a linear move defined my a cartesian position in relation to frame 2. The joint position does not change if my frame changes, resulting in possible crashes.
How do I force the software to use a cartesian definition for the position?
I found some settings in Options>Program that seemed like it would force the output to be cartesian but it doesn't seem to have done anything.
I've made sure I have the latest version and even tried restarting my pc...
I'm using a fanuc r2000 robot with a rj3ib controller
Please advise
Please advise
