I'm trying to use the Elephant Robotics cobot 280 M5, but I'm having trouble setting it up. I'm using the Elephant Robotics myCobot Pro-600 in the library as a reference, but I can't tell if this is correct. For example, I set the rotation angle of the joints, but when I move the sliders for each joint with joint axis jog, the arm goes into the 3D model. Is this the correct setting?
H.tanino
The joint data we are using as reference is this PDF.
https://www.elephantrobotics.com/wp-cont...210318.pdf
H.tanino
