How to move the actual robot
こんにちはRoboDKチーム。
RoboDKで三菱ロボット(Mitsubishi RV-7FRL)を動かそうとしています。シミュレータでプログラムして実行することはできますが、実際にロボットを動かそうとするとエラーが発生し、動かせません。接続ステータスを準備できましたが、Pythonプログラムを含むプログラムを実行できませんでした。すべてシンプルなプログラムです。
エラーメッセージなどを添付しますので、解決方法を教えてください。
It seems that error message was not attached, so I will repost it
Are you able to use the "Move Joint" in the "Connection screen"?
Let's say we remove Python from the equation, does it work?
(08-23-2021, 02:29 PM)Jeremy Wrote: Are you able to use the "Move Joint" in the "Connection screen"?
I've been busy for the past week, so my reply has been delayed. I'm sorry.
Before last week I was able to move it with "Move Joint". However, when I tried to move it this week, I got "Win Error 10038" and couldn't move it.
According to what I saw on the internet "WinError 10038" is caused by a socket connection "close" command happening too fast.
Can you try Double-clicking "Disconnect" (double-click has more power than single-click in the connection window, it will really kill everything and reset the log file).
Then "Connect" -> "Get Position"
If it works -> "Move Joint".
