05-13-2024, 09:48 AM
(This post was last modified: 05-13-2024, 09:48 AM by keunjun.)
Thank you for the reply, Albert.
With your instruction, I have to get the point info one by one. Am I right? Is there a way to get the points stored in machining project at once?
227
It is not possible to get the points of the robot machining project using the API. However, you can generate a program and use a CSV post processor to obtain the points.
Threads: 22
The documentation for item.GetPoints(feature_type=1, feature_id=0) says that the returned points are provided in [XYZijk] format in relative coordinates.
My question is: what coordinate system are these points relative to?
I would like to use the points as a way to identify items with different names that are located at the same point in 3D space.
Thank you.
