How to view RoboDK script output
Is there a way to view the output from scripts when running a RoboDK simulation?
For example when I am using python, I would like to know the output for a certain variable. So I would print that variable unto the console. I do not know how to view the serial output on RoboDk.
Grateful for the help!
You can right click on the script and select Edit Python Script and then run from the open VS Code window. You will see the output then.
(07-05-2021, 02:18 PM)Vineet Wrote: Hello,
Thanks for the answer, I will try that!
