IF else commands in Robodk
Hello RDK People
Im really new in roboDK. Regarding that i have maybe a really "stupid" question, but i havent found a soultion from robodk help to solve it .
I have made 2 diffrent movement programs in robodk. Let´s call them Prog1 and Prog 2.
Now i want make condition if and else.
How i can do it in RoboDK ?
I can generate main program, that will run first Prog1 then Prog2, and edit it by hand and add the conditions.
Like that, but i hope RoboDK has better solution inside the program how to do it
 VERSION:1
 LANGUAGE:ENGLISH
MODULE MOD_MainProgram
PERS tooldata rdkTool := [TRUE,[[0,0,0],[1,0,0,0]],[20,[0,0,200],[1,0,0,0],0,0,0.005]];
PROC MainProgram()
!Program generated by RoboDK v5.2.1 for ABB IRB 6400 2.8 120 on 11/02/2021 20:34:18
!Using nominal kinematics.
if andur_1=HIGH THEN
Prog1;
else
Prog2;
ENDIF
ENDPROC
PROC Prog1()
MoveJ [[2145.000,0.000,1143.934],[0.70710678,0.00000000,0.70710678,0.00000000],[0,-1,-1,1],[9E9,9E9,9E9,9E9,9E9,9E9]], v200, fine, rdkTool;
MoveJ [[2145.000,870.641,1143.934],[0.70710678,0.00000000,0.70710678,-0.00000001],[0,0,-1,1],[9E9,9E9,9E9,9E9,9E9,9E9]], v200, fine, rdkTool;
MoveJ [[2145.000,870.641,1981.626],[0.70710678,0.00000000,0.70710678,0.00000000],[0,0,-1,1],[9E9,9E9,9E9,9E9,9E9,9E9]], v200, fine, rdkTool;
MoveJ [[2145.000,3.905,1981.626],[0.70710678,-0.00000001,0.70710678,0.00000000],[0,0,-1,1],[9E9,9E9,9E9,9E9,9E9,9E9]], v200, fine, rdkTool;
MoveJ [[2145.000,889.036,1158.989],[0.70710678,-0.00000001,0.70710678,0.00000000],[0,0,-1,1],[9E9,9E9,9E9,9E9,9E9,9E9]], v200, fine, rdkTool;
ENDPROC
PROC Prog2()
MoveJ [[2145.000,0.000,2075.000],[0.70710678,-0.00000001,0.70710678,0.00000000],[0,0,-1,0],[9E9,9E9,9E9,9E9,9E9,9E9]], v200, fine, rdkTool;
MoveJ [[2145.000,41.161,2382.972],[0.70710678,0.00000000,0.70710678,0.00000000],[0,1,-2,1],[9E9,9E9,9E9,9E9,9E9,9E9]], v200, fine, rdkTool;
MoveJ [[2145.000,695.675,2382.972],[0.70710678,0.00000000,0.70710678,0.00000000],[0,1,-2,1],[9E9,9E9,9E9,9E9,9E9,9E9]], v200, fine, rdkTool;
MoveJ [[2145.000,695.675,2135.282],[0.70710678,-0.00000001,0.70710678,0.00000000],[0,1,-2,1],[9E9,9E9,9E9,9E9,9E9,9E9]], v200, fine, rdkTool;
MoveL [[2145.000,55.244,2135.282],[0.70710678,0.00000001,0.70710678,0.00000001],[0,1,-2,1],[9E9,9E9,9E9,9E9,9E9,9E9]], v200, fine, rdkTool;
ENDPROC
ENDMODULE
If/then/else statements are not supported when you use the UI. Your workaround is the best way to go unless you want to use the API. For example, you could write a small script that emulates your logic and triggers the corresponding program.
I'm sorry we can't be of more help at this moment.
If you download the latest version of RoboDK, you can use "IF" and "WHILE" statement.
For it to work, you need to activate "Flow control statement" in "Tools"->"Options"->"Station"
I attached an example station.
Let us know if you have any comments.
.rdk   FlowControlStatements.rdk (Size: 1.11 MB / Downloads: 1,354)
Dear Jeremy,
My colleague tried a project using  "IF" and "WHILE" statements, but he found something wrong in his project as attached.
Could you specify what the cause is about not working well IF statement in his project?
Best Regards,
Hiroe
.zip   sample (1).zip (Size: 3.18 MB / Downloads: 813)
For it to work, you need to activate "Flow control statement" in "Tools"->"Options"->"Station".
I forgot to mention it in my first comment, I edited it.
Hi Jeremy
Is there a reason why the Flow control statement is not enabled by default ?
Flow control statements in RoboDK is an experimental feature. To properly support this feature we would have to improve all our post processors to properly generate these flow control statements when generating robot programs.
