IconSet Example
There is a good chance that I am misunderstanding what the "IconSet" command does.  I am hoping that it will change the icon next to the instruction in the station.  Like this...
I have tried this command:
currentProg.Instruction(n).setParam('IconSet', "C:/images/LargeNext.png")
Do I need to resize the icon?  I attached the file.  I was hoping that Qt would handle the scaling.
Thanks for your help,
Henry
IconSet applies to custom/generic nodes only, not instructions. These custom/generic nodes must be added using "AddItem". Example: RDK.Command("AddItem", "item name").
Instead, if you want to show a custom icon to a custom instruction you should use customInstruction on a program to add an instruction with a custom command, icon, etc:
https://robodk.com/doc/en/PythonAPI/robo...nstruction
