Threads: 5
Hi I am unable to import points from Inventor.
Importing curves works fine.
I choose the point and the surface and then click OK and nothing in RoboDK happens.
Any help?
I am very close to finish the job.
BR
V
Threads: 5
to be more specific, I am trying to import point, that is on the curve, that is easy to import. So there should be no problem with the geometry.
Threads: 5
I am able to import point that is on the edge of 2 surfaces. I click point, then 1st surface, then 2nd surface, then OK.
The point appears in ROBODK!!
What I need is, that I select point, then a surface where the point lies, then OK.
Threads: 5
another update. I am able to import points, that are on the edge of the surface to which it is normal (1)
I am NOT able to import point, that is somewhere in the middle of the surface (2 f.e.)
224
Hi Venari,
Thank you for your feedback.
Can you provide the 3D model (Autodesk Inventor file)?
