Imported Robot Path - Point/Target Location in GUI
I have imported a robot path from fanuc .ls and it simulates with MoveL and MoveC instructions
MoveJ P1
MoveL P2 etc
Just as I showed the instructions from the hidden program, how do I show the targets or points from this import in the GUI?
Jacob
Hi Jacob,
Once you have a program in RoboDK (even if you imported it from a Fanuc LS file), you can right click an instruction and select Select Target. This will make the target appear in the station.
You can also bulk select movement instructions and retrieve the targets.
