Imported .png shows up blank after saving .rdk
Version: 5.6.0 . 23250 (Ubuntu)
To reproduce:
  file...open a .png file.  Image appears as expected
  file...save .rdk
  file...open the .rdk you just created
Now there's just a gray rectangle where the image should be.  (Also does this with .jpg)
This behavior is expected unless you activate the option to save texture data and image data. You can enable this by following these steps:
  1. Right click your station
  2. Check the option Save texture data
  3. Check the option Save image data
This setting is saved with the RDK project.
