Importing curve path with XYZABC data
Hello community,
I am trying to import a .csv path file to simulate the motion of a passenger during a vehicle rollover crash.  The path data is in X,Y,Z,A,B,C format where A,B and C are rotations about the robot base axis.
Is there a way to import this format?  I have the same path in XYZijk unit vector format however this does not account for the roll about the unit vector.
Jeff
Hi Jeff,
If you go to "C:/RoboDK/Library/Scripts" you should find a script called "ImportCSV_XYZWPR".
That should be a good starting point for you.
