06-11-2025, 09:44 AM
Dear RoboDK team.
I would like to report an issue I encountered when following your instructions for installing the Fusion 360 plugin.
In your documentation, you refer to the following path for installation:
– however, this path does not work when installing the plugin on Windows 11.
After testing, I found that the only way to make the plugin work is to extract the contents of the ZIP file to the following directory instead:
I hope you will consider updating your guide with the correct path to prevent confusion or installation issues for other users.
Thank you in advance.
C:\RoboDK\Other\Plugin-Fusion360\RoboDK\– however, this path does not work when installing the plugin on Windows 11.
C:\Users\Username\AppData\Roaming\Autodesk\Autodesk Fusion 360\API\AddIns\RobodkI hope you will consider updating your guide with the correct path to prevent confusion or installation issues for other users.
