Threads: 4
0
The method works with the generation of program trough the post processor.
But is there a solution to send an ID program to the apiur( bin file) during the runonrobot mode ?
Threads: 1
0
08-31-2020, 11:11 PM
(This post was last modified: 05-24-2024, 07:44 AM by Albert.)
I understand the process you are describing about sending Program "IDs" to the driver script. You mention modifying the driver script and elaborate with the code snippet above. Could you please be more specific about what script I should be editing?
There is no editable UR driver script in the following location: C:\RoboDK\api\Robot. When you say "on the UR side of the driver", I am not sure I fully understand what you mean.
Thanks in advance! Please let me know if you need any other information!
Threads: 2
219
Hi Trevorb,
Please contact us via email and we'll provide you with the required files.
Threads: 2
219
Hi Pedram,
I just got back to you on the other thread to properly map tool outputs for your UR robot.
Inserting custom code is not supported for all robots when you use the run on robot option (drivers).
