Threads: 1
Hi Albert, I just wanted to post an update on the situation. So far the Fusion 360 Add-In has no problems. I recently installed the latest versions of Inventor CAM Ultimate and RoboDK on another PC but the same problem with the non-functional "Load NC Program" button still persists.
226
Can you check if you have the post processor camplete.cps?
Can you generate NC programs with this post processor or any other post processors?
Can you specify the exact version of Autodesk Inventor you are using? We can try to reproduce this issue.
Threads: 1
When I use the camplete.cps post processor, I can drag and drop the toolpath into RoboDK. I totally never thought of trying to just drag and drop post processed tool paths. So that works, thanks for the tip.
I assume the "Load NC Program" button would just transfer a camplete.cps file to RoboDK or are there any other adjustments I should keep in mind?
I use Inventor Professional 2025 build: 162, release: 2025.0.1
226
Thank you for letting us know.
We'll be taking a deeper look and try to make sure that the Load NC program button works with the latest version of Autodesk Inventor.
