Issue Opening Project in RoboDK
Hello RoboDK Support Team,
I'm using company license.
RoboDK suddenly shut down while using the program. This happened about 2 times, so I rebooted my PC. And the following error occurs and the .rdk file does not run. I have 700Gb storage.
The error message is "Problems reading file: The RoboDK Station file is corrupted or there's not enough available space. Errors will follow."
i'm trying to attch the rdk file, I couldn't attach it because it is empty. How can i send you the file?
Thank you.
Attached Files Image(s)
Unfortunately, if the file is empty (size is 0 kB) there is not much we can do. This could have happened because of errors writting to disk such as low space left or the file being used by another application. Was the file open in another instance of RoboDK?
