02-21-2020, 07:38 PM
I am trying to set up RoboDK to reflect our tool setup for machining using our KUKA robot. Our spindle is calibrated in the KUKA manner, with the spindle and cutting tool aligned with the X axis of the tool frame, not the Z. How do I set up RoboDK (or an individual machining operation) to take that into account so that the machining setup properly orients the tool?
Is it some combination of the "Path to tool offset", "Frame offset" and "Tool offset" in the machining configuration? Does it have anything to do with the "Default tool X axis orientation" in the RoboDK CAM options?
Or is there no way to use RoboDK's machining setup if the spindle axis is the X axis of the tool frame? For compatibility with other software tools (and KUKA's own logic) I need to keep tool frame as is.
Thanks for any guidance.
