KUKA program error with BAS ex_BASE
I have created a very simple Program in roboDK to test it on our Kuka robot mounted on a custom Linear track but the robot throws an error when reading instruction BAS(#ex_BASE,1)
Error KSS01444: Array index inadmissible
I have already checked and both MACHINE_DEF and BASE_DATA are properly defined
INT MAX_BASE=32
DECL FRAME BASE_DATA[32]
BASE_DATA[1]={X 703.357605,Y -2062.17334,Z -305.790497,A 0.0919634551,B -0.398787886,C -0.0776457191}
BASE_DATA[2]={X 0.0,Y 0.0,Z 0.0,A 0.0,B 0.0,C 0.0}
BASE_DATA[3]={X 0.0,Y 0.0,Z 0.0,A 0.0,B 0.0,C 0.0}
INT MAX_MACHINES=16
DECL MACHINE_DEF_T MACHINE_DEF[16]
MACHINE_DEF[1]={NAME[] "KR 210 R3100-2",COOP_KRC_INDEX 1,PARENT[] "WORLD",ROOT {X 0.0,Y 0.0,Z 0.0,A 0.0,B 0.0,C 0.0},MECH_TYPE #ROBOT,GEOMETRY[] "ObjectId = 686633033"}
MACHINE_DEF[2]={NAME[] "MG_ME_260_KSP40",COOP_KRC_INDEX 1,PARENT[] "WORLD",ROOT {X 0.0,Y 0.0,Z 0.0,A 0.0,B 0.0,C 0.0},MECH_TYPE #ERSYS,GEOMETRY[] "ObjectId = 531816951"}
MACHINE_DEF[3]={NAME[] " ",COOP_KRC_INDEX 0,PARENT[] " ",ROOT {X 0.0,Y 0.0,Z 0.0,A 0.0,B 0.0,C 0.0},MECH_TYPE #NONE,GEOMETRY[] " "}
DEF  BAS (COMMAND :IN,REAL_PAR :IN )
;FOLD BAS ()
  DECL BAS_COMMAND COMMAND
  REAL REAL_PAR
  SWITCH  COMMAND
    CASE #EX_BASE
    EX_BASE (REAL_PAR, 0 )
  ENDSWITCH
END
Do i need to change anything in  EX_BASE (REAL_PAR, 0 )? I see that the second argument (0) is is hardcoded
Looking at the generated code, i don't find anything wrong with it and the Cell seems to be properly configured as i am able to jog the external axis with the teaching pendant.
The zip file contains bas.src, machine.dat, config.dat and the generated .src
&ACCESS RVP
&REL 1
&PARAM TEMPLATE = C:\KRC\Roboter\Template\vorgabe
&PARAM EDITMASK = *
DEF _2_1_2_Axis_Prof ( )
; GLOBAL INTERRUPT DECL 3 WHEN $STOPMESS==TRUE DO IR_STOPM ( )
; INTERRUPT ON 3
;FOLD Initialise and set default speed
BAS (#INITMOV,0)
BAS (#VEL_PTP,100)
BAS (#ACC_PTP,20)
$VEL.CP=0.2
BAS (#TOOL,0)
BAS (#BASE,0)
;ENDFOLD
;;FOLD STARTPOS
;$BWDSTART = FALSE
;PDAT_ACT = PDEFAULT
;BAS(#PTP_DAT)
;FDAT_ACT = {TOOL_NO 0,BASE_NO 0,IPO_FRAME #BASE}
;BAS(#FRAMES)
;;ENDFOLD
$ADVANCE = 5
;FOLD ---- Quickly skip BCO ----
; PTP $AXIS_ACT
;ENDFOLD
;FOLD ---- GO HOME ----
; PTP {A1 0.000, A2 -90.000, A3 90.000, A4 0.000, A5 0.000, A6 0.000, E1 0, E2 0, E3 0, E4 0, E5 0, E6 0}
;ENDFOLD
; Program generated by RoboDK v5.9.3 for KUKA KR 210-2 3100 on 24/10/2025 08:36:41
; Using nominal kinematics.
$APO.CPTP = 1
$APO.CDIS = 1.000
Wait for StrClear($LOOP_MSG[])
$LOOP_CONT = TRUE
$LOOP_MSG[] = "Operation name: 2 1/2 Axis Profiling"
$LOOP_CONT = TRUE
SetRPM(8000.0)
$VEL.CP = 1.00000
; ---- Setting reference (Base) ----
; BASE_DATA[1] = {FRAME: X 722.860,Y 2431.830,Z 246.206,A -0.081,B -0.400,C 0.091}
BAS(#ex_BASE,1)
; ---- Setting tool (TCP) ----
; TOOL_DATA[1] = {FRAME: X 83.420,Y -2.020,Z 467.440,A 0.000,B 45.000,C 0.000}
$TOOL = {FRAME: X 83.420,Y -2.020,Z 467.440,A 0.000,B 45.000,C 0.000}
; $TOOL = TOOL_DATA[1]
; Hide cutters
; Show Tool 1
PTP {A1 -16.86340,A2 -32.89350,A3 109.20600,A4 -109.03200,A5 39.15480,A6 162.13200,E1 2810.55000} C_PTP
LIN {X 1047.300,Y 166.530,Z 56.000,A -105.420,B 0.000,C -180.000,E1 2810.60000} C_DIS
$VEL.CP = 0.07000
LIN {X 1047.300,Y 166.530,Z 50.000,A -105.420,B 0.000,C 180.000,E1 2810.60000} C_DIS
LIN {X 1053.650,Y 166.530,Z 50.000,A -105.420,B 0.000,C -180.000,E1 2812.54000} C_DIS
CIRC {X 1058.140,Y 168.390,Z 50.000,A -105.420,B 0.000,C 180.000,E1 2812.05000},{X 1060.000,Y 172.880,Z 50.000,A -105.420,B 0.000,C 180.000,E1 2808.13000} C_DIS
$VEL.CP = 0.13333
LIN {X 1060.000,Y 1239.750,Z 50.000,A -105.420,B 0.000,C -180.000,E1 1741.71000} C_DIS
$VEL.CP = 0.07000
CIRC {X 1058.690,Y 1243.610,Z 50.000,A -105.420,B 0.000,C 180.000,E1 1737.50000},{X 1053.650,Y 1246.100,Z 50.000,A -105.420,B 0.000,C 180.000,E1 1733.43000} C_DIS
LIN {X 1047.300,Y 1246.100,Z 50.000,A -105.420,B 0.000,C 180.000,E1 1731.49000} C_DIS
$VEL.CP = 1.00000
LIN {X 1047.300,Y 1246.100,Z 56.000,A -105.420,B 0.000,C 180.000,E1 1731.49000} C_DIS
LIN {X 1047.300,Y 1246.100,Z 156.000,A -105.420,B 0.000,C -180.000,E1 1731.44000} C_DIS
$VEL.CP = 0.07000
END
Also, when going the direct method
$BASE = EK(MACHINE_DEF[2].ROOT, MACHINE_DEF[2].MECH_TYPE, BASE_DATA[1])
I get Error KSS 1582: Kinematic instruction inadmissible
Linear track motor:  MG_260_180_30_S0
Robot : KR210 R3100-2
Controller: KR C4
OS: KSS 8.6.13 HFI
.zip   Files.zip (Size: 24.74 KB / Downloads: 334)
The hardcoded index 0 in the BAS function call is probably the issue. You can try changing it to 1 or 2 in the BAS.src file. You can see that the EX_BASE function points the second parameter of the BAS function to the MACHINE_DEF array.
Your MACHINE_DEF array in the config.dat file has nothing at index 0 but it has the following definitions for index 1 and 2:
Alsso, for your information, you can find the EX_BASE function code in the BAS.src file:
DEF  EX_BASE (BASE_NO :IN , MACH_IDX : IN)
  INT BASE_NO, MACH_IDX
  IF BASE_NO > 0 THEN
    IF BASE_CORR_ON AND M_BAS_COR_ON THEN
      $BASE=EK(MACHINE_DEF[MACH_IDX].ROOT,MACHINE_DEF[MACH_IDX].MECH_TYPE,BASE_CORR:BASE_DATA[BASE_NO]:M_BASE_CORR)
    ELSE
      IF M_BAS_COR_ON THEN
        $BASE=EK(MACHINE_DEF[MACH_IDX].ROOT,MACHINE_DEF[MACH_IDX].MECH_TYPE,BASE_DATA[BASE_NO]:M_BASE_CORR)
      ELSE
        IF BASE_CORR_ON THEN
          $BASE=EK(MACHINE_DEF[MACH_IDX].ROOT,MACHINE_DEF[MACH_IDX].MECH_TYPE,BASE_CORR:BASE_DATA[BASE_NO])
        ELSE
          $BASE=EK(MACHINE_DEF[MACH_IDX].ROOT,MACHINE_DEF[MACH_IDX].MECH_TYPE,BASE_DATA[BASE_NO])
        ENDIF
      ENDIF
    ENDIF
  ENDIF
    CONTINUE
    $ACT_BASE=BASE_NO
END
Has anyone successfully used this cell before?
We are able to move the external axis (linear track) with the teaching pendant (jog) but it is the first time we try running a program with synchornized axes.
The robot controller came preconfigured from the factory with the Linear track
Great, what did you end up changing to make it work?
We are unable to run the program generated from RoboDK when we have synchronized axes as it includes the BAS(#ex_BASE,1) instruction. When we deactivate it we can move the robot but no the track.
I also noticed that the generated file does not set the proper frame/tool so i have to change the .src manually to include BAS(#TOOL,#) and BAS(#BASE,#)
Do you use the BAS function?
Did you change the hard coded index of the call to EX_BASE?
You can find some examples to customize your post processor for KUKA robots (specially when setting the coordinate system) here:
https://robodk.com/doc/en/Post-Processor...amesFilter
I have tried running $BASE = EK(MACHINE_DEF[2].ROOT, MACHINE_DEF[2].MECH_TYPE, BASE_DATA[1]) witch is basically the same thing as EX_BASE (2, 1 ) and ran into KSS 1582: Kinematic instruction inadmissible so i dont think it would solve the issue. Besides, for what i have seen in other forums and from kuka support itself, it is never a good idea to temper with bas.src. Correct me if i am wrong
I was able to run it when manually changing BAS(#ex_BASE,1) to BAS(#BASE,1). From the kuka documentation, BAS(#ex_BASE,1) is used for assigning a referece frame linked to a mechanism (rotary table for example). in my case, BASE[1] is linked to the world (fixed).
I am trying to edit the KRC4 postprocessor so that it automatically uses BAS(#base,#) instead but i dont see any conditional to when it should be #BASE and when #ext_BASE. On the original post you can see that the frame is not linked to the mechanism at all so i would have expected the post processor to use Bas(#Base)
You can check the number of axes using the nAxes variable in your post processor and decide if you want to export one type of base or another.
Example:
from KUKA_KRC2 import RobotPost as MainPost
class RobotPost(MainPost):
    def setFrame(self, pose, frame_id, frame_name):
        """Change the robot reference frame"""
        if self.nAxes <= 6:
            # We only have a robot arm
            self.addline('; BASE_DATA[8] = {FRAME: %s}' % (self.pose_2_str(pose)))
            self.addline('BAS (#BASE,8)')
        else:
            # We have a robot arm and external axes
            self.addline('BAS (#ex_BASE,8)')
A more logical check would be if the frame is attached to a mechanism or not in the postprocessor. Although it makes a call to Robolink which its not recommended
Here is my solution:
        # use standard if linked to a mechanism
        frame = RDK.Item(frame_name)
        if frame.Parent().Type() == robolink.ITEM_TYPE_ROBOT:
            super(MainPost, self).setFrame(pose, frame_id, frame_name)
            return
        else:
            # Implement a custom setFrame
            self.addline('')
            self.addline('; ---- Setting reference: %s ----' % frame_name)
            self.addline('; BASE_DATA[%i] = %s' % (frame_id,self.pose_2_str(pose)))
            self.addline('BAS (#BASE,%i)' % (frame_id))
            self.addline('; --------------------------')
    pass
    def setTool(self, pose, tool_id, tool_name):
        """Change the robot tool frame"""
        self.addline('')
        self.addline('; ---- Setting reference: %s ----' % tool_name)
        self.addline('; TOOL_DATA[%i] = %s' % (tool_id,self.pose_2_str(pose)))
        self.addline('BAS (#TOOL,%i)' % (tool_id))
    pass
