Lauching RoboDK from API
I have a small problem, I can't launch RoboDK on my Ubuntu 20.04. If I let the c++ API start it, it just crash with the error:
error while loading shared libraries: libQt5WebSockets.so.5: cannot open shared object file: No such file or directory
So I added to my .bashrc the lines from "~/RoboDK/RoboDK-Start.sh" and the software started, but crash after less than 1 second with a segmentation fault:
./RoboDK
No running instances of RoboDK detected
Starting  RoboDK  v 5.0.2 . 18542  ...
OS:  LIN64
Date build:  Aug 16 2020
Main process ID:  167646
Thread ID:  0x7fcb5ae97bc0
Loading settings...
Failed to acces global parameters file
Setting up default settings...
Default settings set
Settings loaded
Statusbar:  "Language set to English"
Updating recent files menu...
Created language menu
Setting slider style...
Done
Setting up graphics...
Setting up main window...
Starting main window...
LC start...
LC message:  LC device not found
Dongle not found or cannot read
LC start...
Loading plugin:  "CollisionFreePlanner"
"libAppLoader.so"
"libCollisionFreePlanner.so"
Loading plugin file:  "libCollisionFreePlanner.so"
Loading plugin  "CollisionFreePlanner"
Using settings:  ""
Setting up the status bar
Inserting menu at the end of the utilities menu
Setting up the menu bar
"libOPC-UA.so"
"libPluginExample.so"
"libPluginGravity.so"
"libPluginPalletizing.so"
"libPluginRealTime.so"
"libRobotPilot.so"
List of LOADED plugins:
Done list of plugins
Statusbar:  "Loaded 1 plugins"
Reading preferred layout settings...
Done
[1]    167646 segmentation fault (core dumped)  ./RoboDK
And at this point I don't know what to do.. I want to use RoboDK in an embedded way but I can't even manage to turn it on on a fresh Ubuntu 20.04 install
After further test, it seems that launching from the computer directly works, launching over ssh or with an headless computer cannot works.
Is there a way to launch RoboDK without the UI ? or does this require another version of RoboDK ?
And about the add to bashrc I had to make, I'm not sure this is the "clean" way to do it, how am I suppose to do it then ?
You can start RoboDK without the User interface or the OpenGL window by adding the -NOUI command line option.
More information here:
https://robodk.com/doc/en/RoboDK-API.html#CommandLine
