Launch rdk using Robolink without printing rdk logs on stdout
I try to launch RoboDK like this:
rdk = robolink.Robolink(close_std_out=True)
but then my python console output is polluted by the robodk logs.
I can do the following to keep the robodk logs out of my console:
rdk = robolink.Robolink(args=["-DEBUG"],close_std_out=True)
station = rdk.AddFile(station_filepath) #this will fail
however, I can launch the station if I first create a new Robolink instance
rdk = robolink.Robolink() # new instance
station = rdk.AddFile(station_filepath) # now this works
my setup:
robodk python API version: 5.5.0
robodk version: v5.5.0
Ubuntu 20.04.5 LTS
You can pass a file to save your debug output in a file instead of having it through the stdout pipe. You can do so by specifying the path to the text file like this:
rdk = robolink.Robolink(args=["-DEBUG=./path-to-file.txt"],close_std_out=True)
The path-to-file.txt should be relative to the RoboDK executable/binary.
Alternatively, you can also customize the "output_reader" function in the Robolink module to customize the way the output is provided:
https://github.com/RoboDK/RoboDK-API/blo...k.py#L1289
Or feel free to suggest changes to the initalization of the Robolink module and we can make them official.
