Layout Size
I have generate a cell with several machines and a robot and I need to know if its posible to mesure the size of my layout. How many square meters has it, or make a basic measurement on the floor.
1. If there is a function to measure how much floor I would need?
2 How?
Thanks all
Did you use the "measure" tool under "Tool"->"Measure"?
You simply use that to measure both X and Y dimensions of your cell and multiply for your sqr m.
If you have nothing to attach your measure tool to, you can import a simple flat square from our library and use the scale XYZ tool to create a "floor" with the right dimension and then use the measure tool to figure out the floor size.
Learn more about "Scaling" here: https://www.youtube.com/watch?v=MnNHetg3...l8&index=8
