05-06-2025, 06:49 PM
(This post was last modified: 05-07-2025, 11:49 AM by Albert .)
Why can't roboDK figure out interpolation between linear and rotary axes to achieve simple linear motion??
robodk linear.mp4 (Size: 674.54 KB / Downloads: 333)
227
This is intended behavior for 2 axis mechanisms.
05-07-2025, 11:02 PM
(This post was last modified: 05-09-2025, 11:09 AM by Albert .)
How is linear motion intended to be a curve?
227
Linear movements for a 2-axis mechanism is treated as a joint movement in RoboDK.
One and two axis mechanisms are mostly used as positioners to extend the reach of a robot.
Thanks for reply.
Is there any workaround?
I'm planing to make a crane like 3d printer, should i just make my own kinematics and use roboDK just for 3d simulation with my inputs via API, or do you have any better suggestion?
Thanks.
227
05-09-2025, 02:48 PM
(This post was last modified: 05-09-2025, 02:49 PM by Albert .)
If you have a CNC or 3D printer type of mechanism, linear movements with such a 3-axis mechanism or more axes should work.
