Loading APT toolpaths from fusion gives weird circular movements
I get a lot of bad movements importing from fusion 360 cam and apt file (same result).
Nc file included is from my mazak post and is really .eia file (update the forum to support this format?) and works as intended
Circles and swirls everywhere including straight through my workpiece.
.apt   1001.apt (Size: 2.08 MB / Downloads: 476)
.nc   1001 (2).nc (Size: 457.69 KB / Downloads: 498)
.rdk   kuka 16 20.08.24.rdk (Size: 18.9 MB / Downloads: 447)
You should use RoboDK's Addin for fusion. It uses the default G-code that uses the correct G-code standard that RoboDK will properly load (APT ISO 4343).
(10-15-2024, 10:17 PM)Albert Wrote: You should use RoboDK's Addin for fusion. It uses the default G-code that uses the correct G-code standard that RoboDK will properly load (APT ISO 4343).
In the rdk file I added, it is the bottom import. You can clearly see the swirls going everywhere.
in the eia import you can see the proper movement, and the top one is apt file I imported indirectly.
You probably had the Invert arcs automatically option checked in Tools-Options-CAM. I recommend you to keep it unchecked (default setting).
Alternatively, you should can revert to all default settings by following these steps:
  1. Select Tools-Options
  2. Click on Set Default Settings
(10-16-2024, 09:47 AM)Albert Wrote: You probably had the Invert arcs automatically option checked in Tools-Options-CAM. I recommend you to keep it unchecked (default setting).
Of course I did, Thanks!
