MakeTP stops working now and then. Why?
Hi guys,
I'm using 'MakeTP' (RoboGuide) to convert LS files to TP-format. I've configured RoboDK such that this is done automatically. But... so now and then, only LS-files are generated and no TP-files. It works fine and then it just stops doing generating TP-files in the middle of the day. Any idea what could be going on?
See the images for the errors that are generated.
Emile
Attached Files Image(s)
Did the name of the program or the targeted folder change?
No, nothing changed only small changes in a Curve Following Program and its update etc. The problem seems to come and go now and then. Apparently/unfortunately it is not a known issue/bug...
Why do you say it's a known issue? Did you find other occurrences of this?
