Marble robot milling with Kawasaki UX120
Salut. Există cineva aici care mă poate ajuta să creez un cod de frezare pentru un robot Kawasaki UX120? Aș vrea să testez înainte să cumpăr Robodk. Aș vrea să frezeze marmură, precizia poate fi de plus minus 0,5 mm.
Hello. Is there anyone here who can help me create a milling code for a Kawasaki UX120 robot? I would like to test before buying RoboDK. I want it to mill marble, the accuracy can be plus or minus 0.5 mm.
You should be able to use Kawasaki robots for marble robot milling. Accuracy mostly depends on repeatability but with a robot like the Kawasaki UX120 you won't be able to get so accurate since the repeatability is already 0.5 mm.
Also, we don't have this Kawasaki robot in our library but we could add it. We need the 3D files of your robot (preferably STEP or IGES files) to add it to RoboDK. It would also help if you can provide a PDF sketch with dimensions and robot related information (payload, reach, etc).
Mulțumesc pentru răspuns,
un coleg de pe forum a făcut un 3D cu robotul ux100,120,150, dimensiunile sunt aceleași. pe această cale vreau să-ți mulțumesc.
.zip   Kawasaki_UX150.zip (Size: 1.99 MB / Downloads: 280)
I attached the Kawasaki UX150 robot you requested.
Did you model this robot yourself? Or did you use any official geometry provided by Kawasaki?
.robot   Kawasaki-UX150.robot (Size: 186.45 KB / Downloads: 259)
