11-08-2019, 09:04 AM
I made a Simulink model with several Matlab function blocks to get data from the robot from RoboDK, edit that data and send it back to RoboDK.
One thing I need is the speed and acceleration of the robot TCP. I already wrote a function that calculates the speed from the time which went by when moving from one point to another.
Unfortunately, it seems like the block is executed to rare. When I visualize the velocity with a scope block I only get sort of bars and not a continous curve. Additionally the data seem to be implausible.
Is there a way to get the velocity and acceleration continously and straight out of RoboDK?
I got the tip to use the function InstructionListJoints, which should be in the class RobolinkItem. Unfortunately, it wasn't included there.
Function code to calculate the speed:
function [speedX, speedY, speedZ] = getSpeed(x, y, z)
persistent x1 x2 y1 y2 z1 z2 t1 t2;
if isempty(x1)
% First function call -> Initialize parameters
x1=0; y1=0; z1=0;
x2=x; y2=y; z2=z;
t1=0; t2=0;
speedX=0; speedY=0; speedZ=0;
tic; % Start timer
else
% Shift the parameters
x1=x2; y1=y2; z1=z2;
t1=t2;
% Get new values
x2=x; y2=y1; z2=z1;
t2=toc; % Get time since timerstart
tic; % Start timer again
% Calculate the velocity
speedX = abs(x2-x1)/(t2-t1);
speedY = abs(y2-y1)/(t2-t1);
speedZ = abs(z2-z1)/(t2-t1);
end
end
