Mecademic postprocessor not generating robot program
I have made a very simple RoboDK API python program, which appears to run fine.  When Mecademic or Mecademic Python postprocessor is chosen and Generate Robot Program is executed for the python program, it does its run but does not seem to generate any robot program.  No error output is shown, but no file appears in ~/Documents/RoboDK/Programs (or anywhere else under the home tree or /tmp).
I seem to be missing something.  System is Debian 12 (amd64), educational license.
Thanks.
-- Ralph
.rdk   meca-extruder1.rdk (Size: 1.78 MB / Downloads: 329)
You can configure the folder to save programs here:
  1. Select Tools-Options
  2. Select the Program tab
  3. Set the Robot Programs folder
If the issue persists: can you run RoboDK in debug mode and send us the output log? You should see a RoboDK-Start-Debug.sh file in the installation folder of your Debian install.
Es posible hacer que un robot kuka KR 10 R1100 solde una placa PCB y programarla con python?
Quote:Es posible hacer que un robot kuka KR 10 R1100 solde una placa PCB y programarla con python?
Yes, this is possible as RoboDK is a versatile OLP tool.
Please create a separate topic next time
