06-27-2023, 09:47 AM
i just run into the problem that the program i created worked fine when i just use moveJ commands,
however when i use a moveL command, the robot begins to relocate and turns 4th, 5th and 6th axis, instead of executing linear movement to the next target, here is my code, as you can see, it is as simple as it could be:
#Homeposition
robot.MoveJ(pHome)
p2_safety = p2.Pose()
robot.MoveJ(p2_safety*transl(0,0,-150))
#Targets
for x in range(10):
robot.MoveL(p2) #target position
robot.MoveL(p1) #measure position
#Homeposition
robot.MoveJ(pHome)
#Targets
for x in range(10):
